nsapcor
May 13, 2020Tutor
Orbi connect to Present router
My current router is an Arris furnished by Spectrum. Tech support at Spectrum states they do not support any other routers and will be unable to assist in the future if I replace this with the new Orbi. To overcome the drawback, could I leave the Arris connected to the modem and then direct connect the Arris to the Orbi? Tech support advises that under those circumstances. they will have access to the Arris and will note the presence of the Orbi (I do not know how that works) but more importantly, be able to check the signal, connectively and other matters.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- nsapcorTutor
Present equipment is Motorola modem Arris, model TM1602, router by Askey, model RAC2V1K
I believe the ASKEY router can be removed then connect directly to the Arris TM Modem since thats a cable modem. However possible your ISP has special configurations which required the ASKEY Router to be in place.
You can give option#2 a try first if you have access to the host routers DMZ. IF not, try option#3 for the Orbi AX system.
