mrbobcc
Jun 06, 2023Aspirant
Orbi factory reset
Ok no security question.
So simply
1. unplug modem
2. put orbi back to factory reset
3. plug in modem
4. do a Orbi setup like it is new use ssid and password off the bottom of the Orbi
5 old attched devices should migrate to the "new" Orbi
Is that the steps?
Thanks again
Robert
No. If the WiFi devices were configured to use a previous WiFi system, then the new system should be configured to use exactly the same credentials. This will cause devices to connect automatically.
So simply
1. unplug modem
3. plug in modem
4. do a Orbi setup like it is new use ssid and password off the bottom of the Orbi< configure old SSID name and pass word here so that devices will auto connect to the Orbi system once it's setup and you turn off the out going router system.
Is that the steps?
Thanks again
Robert
