LeslieF's avatar
LeslieF
Orbi guest network RBR850 does not turn off
I turned on the guest network once when I had visitors and I thought I turned it off.  Now when I go in the settings, guest network is NOT enabled, but I still see the guest network when I look at the available Wi-Fi networks.
  • FURRYe38's avatar
    After you disabled the GN on the RBRs web page and applied the change, did you do a reboot of the RBR?
  • iyang's avatar
    iyang
    NETGEAR Expert
    Hi LeslieF,
    Can we know what's security mode in guest network?
    Do you set guest network disable in App or Android/iOS App?
    Thanks,
    Iris
  • Some (smartphone-) wifi scanners cache (stale) ESSIDs for a while, did you confirm that the guest network is really still on and operational?
