evry1lovej
Aug 27, 2022Follower
Orbi mesh 6e best setting for fast speed and low ping
What is the best configuration to get most
Out of the mesh.
Out of the mesh.
The one that works?
Truly its more about testing different setups in your own home. When I first purchased a mesh system I moved it around probably every week and tested the speeds to see what worked best in my own home. This is important to try because things in walls (think hvac/foil lined insulation/etc), furniture, and appliances can all impact how the wifi signal propagates. So testing different locations is going to result in optimizing your performance and wifi coverage.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Depending on size of home, you may not need many RBS deployed.
Usually default settings works well.
Ethernet connect the RBS if you have that support in the home.
CAT6 is recommended. CAT6A STP is recommended for 2.5Gb connections.
