Trhorbi4's avatar
Jul 27, 2024
Orbi quad Rbke963 satellite no power when plugged in.
I have an Orbi Quad-Band WiFi6E Mesh System (RBKE963).
‘One of my satellites no longer has power when it is plugged into the adapter power supply plug  (oem). I have tried different outlets, jiggling the connection cable, & reset with a paper clip with no success. I’ve only had it for a little over a year now.. Does anyone have any advice or comments.
Thanks
  • CrimpOn's avatar
    CrimpOn
    The most obvious step is to swap the power adapter for a power adapter from the other satellite.
    If that works correctly, then the power adapter must be faulty.
    If the other adapter does not work, then there is probably a problem with the satellite.
    • Trhorbi4's avatar
      Trhorbi4
      Tutor
      Hi,
      Thanks for your reply. I have already tried the other satellite power cord, and still nothing. Do you know if they just die like this? Should I just replace it?
      thanks
      • CrimpOn's avatar
        CrimpOn
        "just over a year" really sucks, since the hardware warranty is one year.  I would first appeal to Netgear, "Hey guys.  This is unreal. Please give me a break here."  Otherwise, you are truly screwed.
        p.s. My RBR50 is still going strong after almost 8 years,so no, I do not think this is typical for Netgear products.
