Kiwi-Rodney
Jan 25, 2024Aspirant
ORBI RBK 352 Ethernet ports not connecting to the Internet
I have just configured the router of this system to connect as a modem to the ISP fibre interface via the WAN port and I can now connect to the internet through the WiFi but none of the 3 Ethernet connectors will give me access to the internet. Any suggestions...
Problem solved after an update of router and satellite to the latest available and a power reset of downstream Ethernet switches.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network. - Kiwi-RodneyAspirant
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
