gjohn's avatar
gjohn
Initiate
May 13, 2020
Orbi RBK 853 slow speed even with fast connection
I have just finished installing a brand new Orbi RBK 853 system in our home
Router is connecte to the internet via hte network providers Router (set in bridge mode)  with a 1000Mbps Download line - true performance
The ORBI Router connects then troug a home LAN installation capable of 1000Mbps - for a first speed test the ORBI system was able to match that speed, since all devices are connected the speed is down to 90Mbps - This was faster even with my old setup.
How can I find out what is slowing down the Orbi Network? As the Satelites are connected to the router by a fast LAN the available speed should remain fast. Thanks for your help
  • FURRYe38's avatar
    What is this home network that the RBR is connected too?
    What is the Mfr and model# of the ethernet switch in the configuration?
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
    Be sure that CTS and RTS values are changed to 2346 under Advanced Tab/Advanced Settings/Wireless Settings
    I would turn OFF the RBS and speed test a wired PC connected to the RBR first. Then wireless at the router.
    • gjohn's avatar
      gjohn
      Initiate
      Thanks for the swift input.
      Things look better now
      Completely reset and re-installed the network - The error might have been that the satelites did not sync properly by WLAN with the router prior to be connected to the cables. Speed is now better and consistent - Would you suggest to leave the CTS and RTS Values to 2346 - The automatic setup has set those to 64 - Would appreciate your advice on this FURRYe38
      • FURRYe38's avatar
        Great to hear. Thanks for letting us know. Seems that the wireless sync first then ethernet after still seems to be a good process.
        Run it for a while, if you are not in a noise wifi area with lots of neighbors near by, you can raise the value back up. Or if you notice some of your devices don't connect well or at all. I saw with this NEST controllers so I raised mine up.
