LucGov
Sep 21, 2021Star
ORBI RBK850 keeps disconnecting with ISP after firmware update V4.6.3.16
ORBI RBK853 WIFI keeps disconnecting with ISP after firmware update V4.6.3.16
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Have exactly the same issue - keeps dropping the connection over and over again. My biggest regret, was that I paid a lot of money for updating from a perfect working RBK700 ORBI system to the ORBI850 wifi6 system. I will never recommend this.
Yes, I did a power up several times of my ORBI 853. Also power down/up of the provider modem/bridge.
II even did a roll-back of the software to version V4.6.3.9, but that doens't make a change.
The system worked perfect before this FW upgrade.
Any news from the Netgear helpdesk about a fix ?
What happens if you leave the RBR and RBS turned OFF over night then back on first thing in the morning?
Were seeing others post that leaving the Orbi units unplugged for several hours is helping to correct problems seen.
No time frame on when fw new is forth coming. NG doesn't post this.
- bosbosbosAspirant
I have the same issue with orbi RBK850
The master disconnect from the internet usually one time every day.
It started a few days ago. the unit is on V4.6.3.16
Disconnection the network cable from the master to the ISP modem and reconnecting it helps, but the day after it is down again.
- bosbosbosAspirant
This is the CBN CV8560E
regards
Bosbosbos
- Adam87InitiateSame problem here, my Orbi RBK853 keeps dropping wifi signal randomly everyday, I paid $1200 for this wifi mesh system and it's not working properly. I don't want to regret not going with google but this needs to be FIXED ASAP.
