pss16
Jul 19, 2020Aspirant
Orbi RBK852 compatibility with Google wifi
Hi All,
I upgraded from google wifi to the orbi RBK852 router. I have the 3 google wifi routers at home. Is there a way i can connect them to this Orbi router as extensions? This way I can utilize them.
Many thanks in advance for your replies.
Thanks
pss16
Something to try and see. No idea if they will work or not.
If there not AX or tri band supporting, may not work. Try disabling AX mode on the RBR.
Let us know.
- pss16Aspirant
Many thanks for the response. How do I disable the AX mode to try? do i have to use the orbi app to look for the google wifi?
Use a PC or Laptop and connect to the RBRs web page. It's on the wireless settings page.
You'll need to use googles app to get them connected.
