MonkeyManor
Apr 20, 2020Tutor
Orbi RBK852 is not reliable
I have recently purchased the RBK852 for my house and it has to be the worst purchase I have ever made regarding network equipment.
Here are the reasons:
- I test my internet speed from the Orbi app and get 200+Mbps, my devices get 6-30 Mbps. They used to get 100+.
- My devices lose connection while using them and I have to reboot.
- Anytime I turn off my TV or my PS4 I have to delete the wifi connection and reestablish it when I turn the device back on.
- My devices connect to the Router upstairs at 2.4 GHZ vs the Satellite until 3 ft way at 5 GHZ.
It's just not operating as advertised and for the amount of money paid it should function. The model number is not in the drop down.
My firmware is the latest at this time.
In addition, I was on hold for an hour and the CS rep hung up on me.
Your difficulties are not representative of what most of us are seeing with the Orbi AX product. One recommendation to try that helps with older and iot devices that has been frequently recommended:
- Be sure to check your CTS and RTS values. If they are at 64, please change both to 2346. Reboot both RBR and wireless devices. Under Advanced Tab/Advanced Settings/Wireless Settings (use the website admin, not the app)
Other than the above and disabling "Enable 20/40 MHz Coexistence" for 2.4Ghz, I'm running with everything else at default settings. Did you have a mesh router before? Don't expect your devices to seamless connect and switch to the closest satellite, however you should get good connectivity and have strong speeds anywhere within the mesh coverage.
- M
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MonkeyManor wrote:I have recently purchased the RBK852 for my house and it has to be the worst purchase I have ever made regarding network equipment.
Hi,
the Modem is Arris, Surfboard, SB6183.
Home Area is 2,800 Sq Ft.
I followed the link for the setup of the device. One upstairs on East side of house, One Downstairs on West Side.
Channels are Auto. I will try the other channels.
There are two wifi's in the neighborhood.
Be sure to check the CTS and RTS values as well.
