KOR-CAT's avatar
KOR-CAT
Orbi RBK852 Power Adapter Voltage Label(Free Voltage?)
Orbi RBK852, Free Voltage?
I am, Korean.
Does the the Orbi Wifi Power Adapter (purchased in America),
read 100V-240V on the label?
Please advise! Thank you!
  • schumaku's avatar
    schumaku
    Hi,
    I would suggest to strongly avoid buying an US/FCC version (Kit model RBK852-100NAS). While not checked the WiFi 6 Orbi, from experience we know that Netgear's FCC equipment can't be reconfigured for different wireless regulatory areas, the region selection does only allow U.S. (and probably Canada). You might want to look for a RBK852-100EUS or  RBK852-100PAS (don't know if the later does already exist) - these are typically "worldwide" systems allowing the regulatory/country selection.
    • KOR-CAT's avatar
      KOR-CAT
      RBK852, Free Voltage?? Yes or No?
      RBK50(made in usa), It is used in Korea.
      No problem.
      • schumaku's avatar
        schumaku
        Assuming Netgear does ship the same 12V/3.5A power supplies like NETGEAR AC/DC POWER ADAPTER 12V 3.5A FOR 100V-240V AC 50/60HZ (PA7000P) as with many other products ... probably yes. And their factories can (and do sometime) supply other power supplies. I don't know as I'm not Netgear and have no insight on thier product delivery chain.
        No problem.
        Made for the USA probably, unlikley made in USA. Problem ... as it is illegal and can't be changed to Korean region I'm afraid. Your risk - not mine. Not interested in reading later that your mobile or IoT or whatever don't connect, or the KCC (대한민국 방송통신위원회) does ring on your door.
  • FURRYe38's avatar
    This is the sticker from my RBR850. 110-240v
    • KOR-CAT's avatar
      KOR-CAT
      Is the RBS850, AC adapter 110-240V?
      Do you have a picture of the AC adapter sticker?
      Thank you.
      • Bandito's avatar
        Bandito
        Luminary
        Mine is clearly a US/Japan adapter as the input voltage is only 100-120 VAC.  I have attached a picture of the adapter and label.
