eec801's avatar
eec801
Orbi RBK852 unstable speeds
I've had my RBK852 setup for ~18 months running wifi from a google fiber router with 1 gig service. Speeds have been solid throughout the house with a ping of <5 ms and typical upload / download of 400-600 Mbps depending on location.
Beginning earlier this week the network has slowed dramatically and has complete drop-outs at times. Pings range as high as several hundred ms and speeds are <30 Mbps down and <10 up. I've tested at fiber modem as well as run speed tests through the orbi software and there is no deterioration in the internet speed or signal quality, still >1 gig. Have updated firmware, rebooted system and removed and reinstalled but same poor results each time. Final steps I've taken are validating basic settings such as WMM, etc. are set up correctly.
Any suggestions?
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Is or has Armor or Smart Parental Controls been enabled at all?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    What PING results do you see with a wired PC and Ooklas installable speed test app?
    • eec801's avatar
      eec801
      Re: Orbi RBK852 unstable speeds
      What Firmware version is currently loaded? Currently on V4.6.14.3
      What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? GFLT132
      Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended. Yes, and replaced as part of testing.
      Is or has Armor or Smart Parental Controls been enabled at all? No
      All has been normal until earlier this week. Have done multiple reboots following the steps outlined above and comes back with same 'lower' and 'unstable' speed each time. When wired to fiber modem, ping is 1 ms and speeds are >1 gig up and down.
      • FURRYe38's avatar
        Has a power off for 1 minute then back ON with the ISP ONT and router been performed?
        What PING results do you see with a wired PC and Ooklas installable speed test app thru the RBR?
        Still happen with RBS turned OFF as well?
        IF you haven't changed anything then not sure if it's a Orbi issue.
