Polemos's avatar
Polemos
Orbi RBK863SB AX600 Tri Mesh Wi-Fi 6 - 3 Pack
Hi I'm looking for some advice please, I need to improve my Wi-Fi in my house, single floor, but L shaped property, 23 meters wide by 35 meters long building, with each part of the L being approx. 11 meters wide. Walls are all timber framed with wool insulation and Plasterboard.
I have the ability to place a (relatively) centrally located base station connected by Ethernet to my current Modem/Router which I want to continue to use as its also connected to my Alarm and Security system, external watering system and a few other network connected items such as audio and Video distribution panels. my plan is then to setup the two Satellites that come with the 3 pack in appropriate locations so they still talk to the base station but also give adequate coverage of the required areas, the question is does this sound like a feasible plan? and also the specifications on the RBK863SB suggest it is a router only, but I am guessing I will need to set it up as an Access Point so it pulls IP addresses from the existing modem/router DHCP server. is this something i can do easily with the RBK863SB?
Cheers.
  • CrimpOn's avatar
    CrimpOn
    Page 85 of the User Manual describes how to put the router into Access Point (AP) mode:
    https://www.downloads.netgear.com/files/GDC/RBK863S/RBR860_RBS860_UM_EN.pdf
    I am concerned that 35 meters is too great a distance to get good coverage from one AP placed at the connection of the two wings and the other some 16-17 meters away.  Do you plan to connect the two satellites to the router unit with the default WiFi connection or with Ethernet cable?
    (At the very least, I would want to purchase this from a vendor with a liberal return policy.)
    • Polemos's avatar
      Polemos
      Hi thanks for the info, yes I was a little worried about that, I'm assuming the standard working distance from base to satellite is around 9 meters from all the google searches I've done? is there anywhere that gives an expected radius of coverage for each of the base/satellites?
