Gmurakami's avatar
Dec 31, 2020
Orbi RBR 750 issues with Netgear AC1750 cable modem
i recently switched out Spectrum modem with Netgear AC 1750 and have Orbi connected as older cement brick house. Now Orbi speed test won't work and Netgear keeps telling me firmware needs to be upgraded, but I can't access router login site. Considering all devices are netgear I cannot figure out why not working. Considering returning cable modem for Arris modem. Please help with any advice.
Thanks in advance for any help
  • Enjoy. Please mark your thread and solved so others will know. Enjoy. :smileywink:
    Happy New Year.
  • FURRYe38's avatar
    What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance? This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Why do you want to just eliminate the Netgear AC 1750 router all together and just connect the Orbi router to the Spectrum modem, and set the Orbi router in router mode?
    Or are you referring to a different Netgear router?
    • Gmurakami's avatar
      Gmurakami
      Tutor
      To clarify, I replaced Spectrum modem with the Netgear  cable modem. The Orbi router is connected to the Netgear modem.  The Spectrum modem was slow plus I wanted to get away from monthly fees. My house is older and made of cement brick. I need the Orbi router and satellies to extend the coverage
      • FURRYe38's avatar
        Need to bridge or set modem only mode on the NG cable modem if this is a modem with built in router and wifi.
        What C series model is the NG modem?
    • FURRYe38's avatar
      I think he's referencing the NG cable modem which is probably a C series gatway router modem already. So if this is the case, then they just need to configure the modem for modem only mode. Which would be the first step in solving problems.
        Gmurakami
        Tutor
        C6300v2 is tne modem router. I so appreciate everyone trying to help
