Rellis
Sep 28, 2021Aspirant
Orbi RBR350 - Can’t connect solar gateway
A device on my network (solar analytics gateway) communicates to a remote server using MQTT on port 443. It looks like the device is able to make a connection to the remote server, but then gets immediately disconnected. The vendor of the equipment advises that it looks like it being caused by an intrusion detection system or similar. The problem does not occur if it is joined to another network. Eg wifi hotspot on mobile phone.
You have the RBR350.
What firmware is on it?
What modem/gateway is it connected to?
Are you using armor or parental controls?
Are you using access controls?
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
