PhenkQ's avatar
PhenkQ
Follower
Jul 06, 2021
Orbi rbr350 connected using wifi but wont connect wired
Hi,
I have orbi Rbr350. I set the username and password and change vlan setting to number 2 to connect to internet. Wifi working perfectly but it wont connect wired. I can see that it give my wired device ip address, i can run cmd and ping google.com and got a reply but if i open firefox, it wont open any website. Called netgear customer service so many times. They told me to exchange the orbi twice with faulty product reason. Please help. Thank you
  • FURRYe38's avatar
    What wired device do you have connected? Connected to the RBR or the RBS?
    • kin-mye's avatar
      kin-mye
      Tutor
      Hi.
      I have the same issue: RBR350 works with wifi but not wired. I am testing using only router (no satellites). If you don't mind, I put the details of my issue here so that we can share efforts.
      So, did you change the router and the problem persist?
      This is my case.
      To simplify the localization of the issue my network now is very simple:  MODEM (ONT) -> Orbi Router -> Laptop
      The modem ONT is Huawei HG8240H
      When I connect laptop using a ethernet cat6 cable directly to the router, it does no work: I can ping a remote host, but I cannot use a browser or wget. (Using wget -d it stops after Initiating SSL handshake, and does not print "handshake successful").
      In fact yesterday started to work at a given moment, not sure why. Then, I moved forward to use the switch/satellite and it stopped again (wifi ok). I couldn't make it work again (wired), not even with first setup (direct connection router-laptop) and after reboots with power-on cycle.
      I can connet to the configuration page of the router, both using wifi or cable. The IP, DNS, speed test, seems to be ok.
      The firmaware seems to be the last one 4.3.4.8 (but I did not update manually).
      This is what I want to do and how I started:
      MODEM -> Orbi Router -> Switch (unmanaged) -> Orbi satellites and other wired devices.
      I was able to configure the router to remove the one provided by telco company (VLAN, PPPoE credentials, NAT filtering open; use MAC of original router, leave the suggested MTU value for PPPoE 1492, which I think was also the value in the original router).
      Thanks in advance for your help!
      • FURRYe38's avatar
        What happens if you use the ISP modem as your man host router and configure AP mode on the Orbi RBR?
        What is the Mfr and model# of the ethernet switch in the configuration?
        kin-mye wrote:
        Hi.
        This is my case.
