wofie2a
Jun 14, 2020Tutor
ORBI RBR50 Wired Backhaul not working
I have been struggling for 2 days trying to get the wired backhaul working on my Orbi 853 setup with one Wired Backhaul and 1 Wireless Backhaul satellite. I read a lot of posts that said you needed ...
Hambledom
Sep 20, 2020Aspirant
Hi
I have read plenty about how to set up wired backhauls, but what I cannot see is if it is possible to set one up from one satellite (number 3) to another (number 2) where number 2 is connected wirelessly to the router? Is it possible to mix wired and wireless without having to go wired all the way back to the router?
thanks for your help!
- FURRYe38Sep 20, 2020Guru - Experienced User
Anything is possible. You can try it out and see and let us know? I haven't tried that configuration.
Hambledom wrote:Hi
