wofie2a
Jun 14, 2020Tutor
ORBI RBR50 Wired Backhaul not working
I have been struggling for 2 days trying to get the wired backhaul working on my Orbi 853 setup with one Wired Backhaul and 1 Wireless Backhaul satellite. I read a lot of posts that said you needed ...
Hambledom
Sep 20, 2020Aspirant
Hi
I have read plenty about how to set up wired backhauls, but what I cannot see is if it is possible to set one up from one satellite (number 3) to another (number 2) where number 2 is connected wirelessly to the router? Is it possible to mix wired and wireless without having to go wired all the way back to the router?
thanks for your help!
Sep 20, 2020Guru - Experienced User
Anything is possible. You can try it out and see and let us know? I haven't tried that configuration.
Hambledom wrote:Hi
