bosa84's avatar
bosa84
Guide
Sep 15, 2021
Orbi RBR750 and Satellite suddenly started dropping WiFi Devices
I have an Orbi RBR750 plus one satellite (connected via Lan).
Everything worked great for many months, but a few weeks ago the Orbis started disconnecting iPhones and iPads.
Sometimes once a day, sometimes it is impossible to get things working for more than a few minutes.
Right now for example, I had to re-connect an iPad 5 times in the last hour, my iPhone about 3 times.
The wired connections all work great, internet is also working.
I have a feeling it gets bad when 2 or 3 wireless devices are actively doing a lot (zoom session + downloads or so).
Already months ago I realized that when my iPhone had to download a big iOS upgrade or a bunch of app-updates, it would suddenly be kicked out of the WiFi. But it is definitely getting worse, to a degree that it is at daytime keeping us from working and infuriating to the family at night.
Very disappointing, also because before buying these Orbis I already read a few reviews saying that this started happening after a while - I should not have ignored that.
Please help.
  • FURRYe38's avatar
    Is the RBS connected directly the the back of the RBR or is there any LAN swtich in between?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Armor.
    Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    • bosa84's avatar
      bosa84
      Guide
      Thanks FURRYe38, answers below:
      -> the latest: V4.6.3.16_2.0.51
      -> Arris TM1602 (but that did not change)
      -> There is Netgear GS105 in between, but that also did not change and was working fine for months
      -> Using Auto. I will try your recommendations
      -> About 5
Armor.
      -> was always disabled
      -> I only see a "Enable 20/40 MHz Coexistence " but I cannot specify 40. Will try your other recommendations
      • FURRYe38's avatar
        -> About 5
Armor.
        -> I only see a "Enable 20/40 MHz Coexistence " but I cannot specify 40. Will try your other recommendations< Remove the check mark from the box then select apply. This sets 40Mhz only.
        Has a power off for 1 minute then back ON with the ISP modem, Switch and Orbi system been performed since last update?
