wjberey's avatar
wjberey
Orbi RBR750 firmware login issues
Can't login as admin to Orbi RBR 750 router.  If I reboot it I can log in immediately after the reboot but within a short amount of time I cannot get in again (it clocks infinitely).  I'm assuming I need to change a firmware setting to allow me to access the firmware without having to reboot each time.  Appreciate any help.  Thanks in advance.
  • CrimpOn's avatar
    CrimpOn
    There is no setting to allow/disallow admin login to http://orbilogin.net
    The user name is always "admin" and the password is whatever password was entered during setup.
    Can you post a screen shot of what happens when a login is attempted?
    • wjberey's avatar
      wjberey
      Thanks for replying. The browser (whichever I use) just clocks indefinitely. Doesn't even bring up the login. If i reboot the router the browser brings me right to the login and i can get in no problem but this only lasts for a short while before i go back to login again and the browser clocks indefinitely again.
      • CrimpOn's avatar
        CrimpOn
        This took me a while to understand.  Clock means that a circular symbol appears and looks similar to a clock face spinning? And, this is before the authentication box appears? (see attached image)  When I enter "admin" and the admin password, there is a brief period of "clocking" before the Orbi home page appears. But, only a few seconds.
        As this appears with more than one browser, have you tried a different device? (doesn't have to be a computer. Even a smartphone browser can bring up the Orbi web page.  (It won't be useable, what with the phone screen being so small, but it should appear.)
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
    Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
  • FURRYe38's avatar
