DORAN033's avatar
DORAN033
Orbi RBR750 Port Forwarding Issue
Hi there! I have been port forwarding some self hosted sites [using NPM] through my orbi router for about 6 months now, and suddenly it stopped working. As of a week ago, any time I go to the public domain of the router and the correct port, it always takes me to the orbi login website [assuming I'm on the same wifi network]. If I am out of the wifi network, it just says there is nothing at that ip. When on the private ip [192.168.X.X], I am able to access the site, but only on the wifi network, which won't work for what I am using it for. Any advice would be greatly appreciated. Some router information and troubleshooting steps I have taken are found below.
Router: RBR750
Firmware:  V4.6.9.11_2.3.5
Operating Mode: Router
DHCP: On
Previous Trouble Shooting Steps:
Rebooting (x3) | Failed
Restarting Server (x2) | Failed
Reconfiguring NPM (x1) | Failed
  • FURRYe38's avatar
    Is uPnP disabled or enabled on the RBR? Should be disabled if you have any Port Forwarding configurations enabled.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    • DORAN033's avatar
      DORAN033
      Hi there! Thanks for the quick response! The MFR is Netgear, and it is a CM1100. I am not sure where to check if the uPnP is disabled. I'll do the complete system restart in that sequence at XX:30 PM [in 15 minutes] and give you an update. Thanks so much!
    • DORAN033's avatar
      DORAN033
      Hi again! I did the restart that you recommended. The issue is still the same issue and takes be right back to the orbi login page as always. Any other ideas? This is driving me slightly insane.
    • DORAN033's avatar
      DORAN033
      I also think uPNP is on. The setting "Turn UPnP On" is checked. Should I disable that?
