chris8a's avatar
chris8a
Orbi rbr750 wifi speed test slows down
Hey all, I have a RBR750 Orbi WiFi 6 Router AX4200 that has a slow wifi connection for videos.
The google speed test on the router LAN connection (ethernet) shows 100/38 Mbs (great) - It is connected to a telstra fibre internet connection.
If I connect to the wifi, the speed test download starts at 80Mbs (good) then drops down to 3Mbs (bad) after 15 seconds.
I have reset the modem, updated the firmware,  and still no  improvement. It used to work fine. Any suggestions?
  • FURRYe38's avatar
    How are you speed testing? Orbi app or wired PC and web browser?
    What devices are you speed testing with?
    • chris8a's avatar
      chris8a
      Firmware version: V4.6.3.7_2.0.49
      Modem is Telstra technicolor TG799vac. When connecting my new Dell Laptop XPS-15 to the LAN port on this modem the speed test works well at 106/28.2 Mbs and the download speed does not slow down while testing.
      Speed test with this website is:
      - Go to Google.com.
      - Search for internet speed test.
      - Tap or click Run Speed Test.
       (Google partners with Measurement Lab (M-Lab) to run this test.)
      Orbi speed test was done over wifi using the same XPS-15  with LAN cable unplugged.
      download starts at 80Mbs (good) then drops down to 3Mbs (bad) over approx 10-15 seconds
