benjaminoerskov's avatar
Jan 26, 2026
Orbi RBR850 / RBS850 – Constant IoT disconnects (Shelly, robot vacuum, etc.)
I’m experiencing persistent instability with my Orbi mesh network and IoT devices, and I’m hoping someone can help confirm whether this is a known issue or if there’s something fundamental I’m missing.
Setup:
Orbi RBR850 (router)
2 x RBS850 (satellites)
Firmware currently downgraded to V7.2.7.15
House size around 189 m2 + 50 m2 garage
One satellite has been tested both wired and wireless
Problem:
Multiple IoT devices constantly drop off the network and reconnect.
Shelly Gen3 (garage door switch)
Robot vacuum (Deebot)
In Home Assistant I see repeating patterns like:
device turned off
device became unavailable
device became unknown
This happens many times per day, often in the same time windows for different devices, which strongly suggests network instability rather than individual device issues.
Phones, laptops and TVs appear mostly fine. The problem mainly affects 2.4 GHz IoT devices.
Symptoms:
Devices disconnect and reconnect every 20 to 60 minutes
Some devices show weak signal despite being 5 to 10 meters from the main router
Devices sometimes connect to a satellite even when the main router is physically closer
Problems persist across different firmware versions
What I’ve tried:
Downgraded firmware on both router and satellites
Power-cycled everything in correct order (router first, then satellites)
Tested both wireless and wired backhaul
Removed one satellite completely
Disabled 5 GHz temporarily for onboarding
Re-paired devices multiple times
Factory reset Shelly devices
Verified signal strength and placement
None of this has resulted in stable long-term behaviour.
My conclusion so far:
This looks like an Orbi mesh, band steering or roaming issue affecting 2.4 GHz IoT devices. The devices themselves work fine on other networks, but with Orbi they continuously flap between connected and unavailable.
It feels like Orbi is aggressively steering or optimizing in a way that modern phones handle, but embedded IoT devices do not.
My questions:
Is this a known behaviour with Orbi and IoT devices?
Is there any way to force devices to stick to a specific AP?
Is there any way to fully disable band steering or roaming?
Is it possible to create a true 2.4 GHz only SSID without hidden steering?
Are there any recommended settings specifically for IoT stability?
At this point the network is fast but unreliable, which is honestly worse than just slower but stable.
Any insight appreciated, especially from others running IoT-heavy setups on Orbi.
Thanks.
  • FURRYe38's avatar
    Does this happend with One or both RBS turned OFF?
    How many devices in total are connected to the system?
    What channels are being used on the RBR? Try manual channel 1 and 40 or 11 and 48?
    Distance between the RBR and RBS? 30 feet is starting distance between the RBR and RBS and each other.
    Possible that your wifi devices are seeing multiple signals and don't know how to keep locked on to one signal. Call this ping ponging. Its up to devices to pick and choose where they connect too.
    Factory reset the Orbi system and setup from scratch?
    Have you tried the more recent FW version?
    • StephenB's avatar
      Have you tried putting some of the problem devices on the IoT network?
      Do you have other WiFi networks running?  Or do you must mean that the devices were stable before you installed thhe 850?
      • benjaminoerskov's avatar
        benjaminoerskov
        The devices was stable on previous router.
        But also a month ago I saw no issues, they were always on.
        What happned a month ago you ask? I had one rbr and one wireless rbs.
        On 01 Dec I got an extra rbs and connected it via cable further away from rbr.
        Now it doesnt work, no matter which combination of rbr and rbs' I use.
      benjaminoerskov
      Thank you for the quick reply.
      ATM: 17 devices online.
      2.4 GHZ channel: 01
      5GHz channel 36
      I have disabled(unplugged) the center satelite, so atm its rbr in one end of the house, and rbs in the other end of the house. (ca 19 meters distance, connected wired).
      My system auto updated to the newest FW version, I downgraded because  I thought it might be a new bug.
      Any way to save configuration, so I can set this up easily after factory reset? Thinking main, iot, guest networks, port forwards etc.
  • I got rid of my orbi setup and switched to a Ubiquiti Unifi setup. Everything is running smooth now 😍
