Teleport's avatar
Teleport
Orbi RBR850 Wifi speeds very slow using AT&T Fiber even after factory reset
Hello!
I have suddenly noticed a drastic drop in my WiFi speeds on my desktop computer whether connected to the Orbi Router or Satellite. My internet is AT&T Fiber 2G service. The Orbi app on my iPhone reads: 2361.18 Upload and 2355.57 Mpbs download speeds, but when i do a speed test on my desktop only about 10 feet away from my router, my speed tests read: 70.41 Upload and 49.72 Download. As you can see, that is considerably lower. I've been researching, and others have recommended doing a factory reset. I have done this and still, my numbers read the same. The Orbi router is connected directly to the AT&T modem via Ethernet cable.
Anyone know what the problem might be? Thanks in advance!
Hardware: Orbi RBR850
Firmware V4.6.7.13_2.1.9
OS: Mac Monterey 12.0.1
  • plemans's avatar
    Are you testing over 2.4ghz?
    2.4ghz is a much slower band than 5ghz. and its suffers from more interference.
    (even 5ghz isn't going to max out a 2gig connection or even get close).
    Also, att uses their own modem/router combo device and it causes a double nat.
    A double nat happens when you cascade more than 1 router.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Fixes? There’s 3 options but only use 1.
    1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
    2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
    3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
    https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
    • Teleport's avatar
      Teleport
      Hi! Thank you for your time plemans . I'm not sure how to choose which band to test on as I only have one option with my current modem. Looking at the iPhone app though, my desktop is connected to the 5GHz  Wifi. I followed these instructions on the AT&T site re: configuring IP passthrough on my modem:
      https://www.att.com/support/smallbusiness/article/smb-internet/KM1188700
      After doing so, my speeds still remain incredibly slow over WiFi just feet away from the router. I've since brought the router further away from the wall and my computer closer too. Current speedtest has me at: 22.54 dwn/9.06 Up mbps over WiFi, but Orbi app is reporting: 2349.3/2358.43 mbps.
      If i connect the desktop to the Orbi with an Ethernet cable, the speed goes up to: 931.83/938.20 mbps. Still less than half of what the app is reporting.
      • Teleport's avatar
        Teleport
        An update. I tried to downgrade to a previous Firmware version as some people are saying that might be the problem, but when I try to update i get the following message without an option to choose "yes." There is only a "no" button (screenshot attached):
        Firmware Update
        Warning! The firmware version you are trying to upload is older than the one you had.
        Do you still want to continue?
        Current Firmware VersionV4.6.7.13_2.1.9
        New VersionV3.2.17.12_1.4.14
        No
