Ericasjourney's avatar
Apr 26, 2023
Orbi RBR860 - DNS issue with website
Computer: Using 2023 MacBook Air and an older Dell Latitude (work). Also occurred on a former 2013 MacBook Pro as well as my Samsung Galaxy S22+ when connected to the home network.
Connection: Have ISP provided modem/Wi-Fi (It cannot be disabled) plus 2 Orbi RBR860 on 7.2.4.5 firmware (primary plus satellite)
Issue: I have 2 websites I am unable to access due to DNS errors. One is my medical provider health system website and the other is the online Orbi management portal, both giving nearly identical messages. Neither are blocked so far as I can tell from the Orbi security app. I have also attempted connecting directly to the ISP Wi-Fi (again, cannot disable) and have the same results. But when I connect to my company VPN on that computer, pages load perfect as do they when I'm on my cellular network on my phone or hotspot. The odd part is earlier this week as I tried to get to the healthcare website, Orbi flagged it as a possible vulnerability which I placed in the safe list (because it is) but this did not change any behavior of access.
Before I raise cane with the ISP, is there any chance this could be something in the Orbi settings? I cannot access the online portal easily to manage it and the app seems to be missing or hiding settings so a bit bumfuzzled on this one. I openly admit I'm still very green with this network and my settings so apologies for sounding so lost here.
  • It would be useful to see the error messages.  Both the MacBook and the Lattitude have the option to define DNS servers.  What happens if they are set up to use Google DNS? (8.8.8.8) or CloudFlare (1.1.1.1)?
  • FURRYe38's avatar
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Try option #2 first...
    • Ericasjourney's avatar
      Ericasjourney
      Unfortunately I cannot deactivate the ISP WiFi or I lose my TV because they hardcode the cable box to their wifi exclusively (they have monopoly in town). They also do not allow anything other than standard configuration of their equipment for the same reason and they want to force customers to use their wifi equipment exclusively. They are the only broadband ISP in town until late this or sometime next year...
      • FURRYe38's avatar
        Ok, so give option#2 a try and see if this helps with the DNS issue. Just configure the DMZ on the modem for the RBR.
