Edna07
Jan 17, 2025Aspirant
Orbi RBR860 Mesh System
Hi all,
Looking for help with a problem with my RBR860 mesh system. I have 1 x RBR860 router with 2 x RBS860 satellites connected via ethernet backhaul that have been operating fine for the past 1.5 years.
This week I discovered the following:
- no devices connected to satellites
- satellite backhaul status out of sync
- no firmware version showing for satellites
I have removed both of the satellites from the setup and am now having no end of trouble trying to reconnect them. I have tried resetting, syncing and many other support options but am unable to get the satellites reconnected. I continue to get satellite not found error message. The router is still working fine and broadcasting a wifi signal that devices can connect to.
To date Netgear support has not been able to resolve. Please post any thoughts and suggestions on how I may be able to resolve.
Thanks in advance đ
Is your ethernet backhaul running through a switch or directly off the router?
I've never had the mesh system fail to sync with an ethernet backhaul so long as they're on the same firmware as the router.
have you compared the router vs satellite firmware?
- Edna07Aspirant
Thanks for your reply.
Backhaul is straight off the router.
I have included an image that shows my Orbi dashboard and that the satellites are not connected in the attached devices.
This is the issue I am having - I cannot get them the reconnect after removing them so can't even check the firmware version for the satellites. The router firmware is the most current version.
Any other suggestions please?
are you able to factory reset the satellites and then manually resync them?
