PV23QLD's avatar
PV23QLD
Tutor
Sep 18, 2022
Orbi RBRE960 constantly dropping wifi to iPhone?
I recently purchased Netgears Orbi RBRE960 units thinking they were a great product. Unfortunately the reviews I’ve read recently tell a difference story. Seems they still can’t get the wifi drop outs sorted when using apple products. I have Apple iPhones and other devices monitored by iPhones and constantly getting wifi drop outs. Doesn’t matter what time of day, wheee I am in relation to distances from satellites.
Has anyone had similar issues and managed to find a solution. The Netgear technical support line don’t have any answers either.
Thank you.
  • What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? - ZTE ZXHN H268A
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. - yes cat 6 connected
    What Iphone and iOS are you using? - 15.6.1
    What is the size of your home? Sq Ft? -  215 sq meters
    What is the distance between the router and about 10 meters - 30 feet.
    Please turn off 1 RBS if you have two deployed. You may have too much wifi signal for that size of home.
    https://youtu.be/UR0viMLISz4
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. I will try setting manual channel 1 for 2.4Ghz and 40 for 5Ghz and 69 for 6Ghz.
    Any Wifi Neighbors near by? If so, how many? - 6 neighbors <What channels are they using?
    Do you have the IoT and separate 6Ghz radios enabled on the RBR? - yes both enabled. <Are you using the IoT broadcast?
    Please DISABLE the separate 6Ghz SSID broadcast.
    • PV23QLD's avatar
      PV23QLD
      Tutor
      Hi Michaelkenward,
      Ive disabled the private wifi (MAC) address on my Iphone 11 Max Pro - version 15.6.1 and will see how that goes
      Thank you
  • What Firmware version is currently loaded?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Can't say I've seen any issues with my iPhone here. 12 Pro max iOS 16.
    Thank you.
    • PV23QLD's avatar
      PV23QLD
      Tutor
      Hi FURRYe38,
      What Firmware version is currently loaded? - V6.5.3.2
      Thank you
      • FURRYe38's avatar
        Guru
        PV23QLD wrote:
        Hi FURRYe38,
        Couple of options,
