Skycutie
Aug 27, 2020Aspirant
Orbi satellite rbs850 wrong serial number
The WiFi keeps dropping connection. Upon further inspection, I noticed the serial numbers from the app & actual satellite are wrong. How do I fix this? And will this actually make the satellite work?...
Skycutie
Thanks!
Gave us a hard reset...
it’s still in/out. When I test the WiFi speed Orbi has crazy high numbers vs. Speedtest app (which I’m finding much more accurate).
The website reads the same serial numbers as the app for the satellite.
Aug 27, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Be sure to post about Orbi AX questions or information over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Skycutie wrote:
Thanks!
