Yuowin's avatar
Yuowin
Orbi system appears to be rebooting every night around the same time
Hello community.
We are using the Netgear Orbi RBR750 system. Every night around the same time. ~11:35pm our system seems to reboot. All our devices lose WiFi connection. Looking at the LED’s on the router and satellites they’re blinking like they’re rebooting.
Logs don’t show anything before that time, it shows it initialize, get internet connection and all devices reconnect and get IP addresses.
I’ve reset modem and router
Manually installed latest firmware from the netgear site v7.2.6.31.
Factory reset router and all satellites and setup fresh not using a backup configuration and issue still persists.
I’ve seen similar posts but based on the descriptions it’s the internet that’s going out, not the router rebooting itself, or WiFi disconnecting.
Any additional suggestions would be very welcome.
Thank you!
  • plemans's avatar
    What modem/gateway is the router connected to?
    I've seen where users connection to their ISP's lease time was only 24 hours and when the lease expired, it had to renew and caused the same issue.
    • Yuowin's avatar
      Yuowin
      Hey there! It’s a Netgear CM1100, no other gateway just straight to the modem.
      Do you think a renewing lease can cause the WiFi to drop? Literally all our devices lose WiFi, cellphones go to cellular and Apple TV gives a notification that WiFi is disconnected. White blinking light on the router like it’s rebooting and the WiFi reconnects in a minute or so.
      I can check with cox and see how long the IP lease is but this started happening like two weeks ago and it’s been setup the same way since we got the Orbi system in 2021.
      Thank you!
      • Yuowin's avatar
        Yuowin
        I will try downgrading. I checked and it is a 24 hour lease. WiFi went out at 11, router stats show system uptime a minute after WiFi went out so it’s definitely rebooting. Ugh. Hopefully the downgrade helps!
        Thank you
