mooney21's avatar
mooney21
Orbi Top Talker
There is no more possibilities to check, for each device connected, the bandwidth consumption - in real time -  (as we did in previous Netgear routers / WIFI). For me it's a huge weakness for a system that is dedicated to support dozen of devices (and which cost a lot ...).
When Netgear plan to re-introduce this feature ?
What are the possible workarounds to have this feature in the meantime ?
Thanks !
  • Precision : I use an AX6000 Orbi, but I think it is the same issue for all Orbi devices.
  • FURRYe38's avatar
    Seems that Orbi since AC doesn't support this at all. Something you can post about here:
    https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
    Orbi seems to be tuned to the average home user and not more advanced users. The system seems tuned to running as automatic and with out any user configurations settings as possible.
    For the most part Orbi supports having lots of devices connected. It works since the RBS are also picking up bandwidth handling abilities and helping share the load of many connected devices. I've seen others with 50+ devices post having good experiences with Orbi systems.
    If Orbi isn't something tuned for your liking, then you might find a router that does and use the Orbi in AP mode to take advantage of the wifi MESH system. You can connect Orbi to any router.
    • kildare's avatar
      kildare
      Luminary
      However using a router and the Orbi in AP mode couldn't solve the problem of mooney21
      as he needs to check the bandwidth consumption for each connected device...
      • FURRYe38's avatar
        That maybe handled by what ever router he gets that can check each device. The Orbi in AP mode is just mostly pass thru traffic to the up stream router.
