sjtNJ
Nov 09, 2019Guide
Orbi Wi-Fi 6 Satellites
I may be putting this in the wrong place. Simple question, how many Orbi Wi-Fi 6 satellites can I add to my Orbi Wi-Fi 6 router (it came with 1, but I need more range).
Am I also able to supplement with other Orbi (not Wi-Fi 6) satellites? Will it work, even though I give up some speed?
I have about 12k square feet across 3 levels. I had 7 Google Wi-Fi units and it worked fine but not taking advantage of our speed.
Thanks for the help!
- ekhalilMasterLooking into the telnet parameters, I can see that the software limit for the number of Satellites in the system is 8.
Satellites in the software are numbered sat_0 up to sat_7, so seems that this is the max number of possible connected Satellites in Orbi AX - Sevo123ApprenticeNetgear had a live on the orbi AX unit today on YouTube live and Facebook live... I asked about the satellites. They said in the coming weeks it will be available. Finally!!!
Video link https://youtu.be/xPVGv0IHVao- FURRYe38Guru - Experienced User
Yep.
