tinacioffi's avatar
tinacioffi
orbi wifi 6 rbk852 drops off frequently
My Orbi Wifi 6 AX6000 RBK852 system drops internet connection for about a minute or less about 5-10 times a day. It is not my modem (devices connected directly to that Wifi never lose signal. I have a brand new Non Managed Netgear switch (which works great with my OLD router) that is also not the problem. Netgear's tech support was not able to figure it out and actually swopped the device for a replacement (assuming it was a hardware issue) and the new one is doing exact same thing. I feel there must be a setting in the orbilogin.net configuration panel but not sure where to start. My ISP is Optimum with a Altice UBC1326 Modem. Does anyone have any suggestions before I sell this router on E-Bay, broadcast a terrible review on social media and just go my merry way???
  • FURRYe38's avatar
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    What is the Mfr and model# of the ethernet switch in the configuration?
    What kind of problem are you seeing with the Switch?
  • FURRYe38's avatar
    Any progress on this?
    • tinacioffi's avatar
      tinacioffi
      No progress so far.
      I asked Optimum (my ISP) to switch me to bridge mode. They were unable to do so. They were also unable to turn off the WIFI radios on their modem.
      I also tried to go into AP mode but did not have an internet connection at all when I did that.
      I am starting to lose hope.
      Thanks
      • FURRYe38's avatar
        ISP couldn't set bridge or disable wifi radios...you might ask for escalated suppport for help with there modem...or ask the ISP if there is a modem only option that you can used instead of this gateway modem you currently have.
