anthonycwmak's avatar
anthonycwmak
Follower
Feb 14, 2024
Orbi with Superloop?
Is it possible to use Netgear Orbi with Superloop's NBN?
>>If so, is there any special setup that is required? <<
(I have an Orbi Mesh WiFi 6 System - AX5400.
And currently I have a modem from NBN modem I got from TPG.
And I think I am on NBN HFC on my place)
  • FURRYe38's avatar
    Something to discuss with the ISP.
    Orbi works with most ISP equipment with a ethernet connection to the Orbi router.
    Good Luck.
  • plemans's avatar
    FURRYe38 is correct in that it should work with pretty much anything that has an ethernet connection.
    The question is what settings are needed.
    what modem/gateway is it from the ISP?
    Some can be put in passthrough/modem only mode and allow you to direct connect the orbi to it.
    Some can have the orbi's IP address into their dmz.
    And others need the orbi put in access point mode. All depends on what specific gateway you have
