sujay265
Jun 20, 2025Tutor
Orbi960 Frequent Internet Disconnection
Hello All,
I have been using Orbi960 since 2 years without any problem and works like a charm. From 23 May 2025, I am facing frequent internet disconnection, Internet disconnects very 5 to 10 min and then comes back.
My Setup.
1 RBRE960 connected to ISP modem (1 Gbps speed) (placed in living room)
1 RBSE960 connected to RBRE960 Wired Backhaul (placed in bedroom)
The backhaul connection status shows good
The devices connected to RBRE960 in the living room get good internet connection and never drops out and works fine.
However all the devices connected to the RBSE960 place in the bedroom frequently gets disconnected and drops internet connection. When i move my cellphone from bedroom to living room it gets connected to the RBRE and works well.
I thought it might be some problem with the RBSE960 and i swapped wit with my second spare RBSE960 (wire backhaul) but the problem persisted. I changed the backhaul network cable, still did not resolve the issue.
Rebooting the system solves the problem temporarily, but surfaced 30 min later.
I am stuck now dunno what to do. I believe the recent firmware update is causing the issue, not sure.
4 years back had the same issue with RBK50, worked well for 2 years, then same problems started and replaced with RBK960. Looks like some inherent problem with Orbi systems,
Any support i this regards is much appreciated
Sujay
1 Reply
Does the front LED on the RBR turn PINK or blink WHITE when this happens
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Who is your ISP your connected with?
Is IPv6 enabled ono the RBR?
Are you using ISP DNS or custom DNS?Able to access the RBR WEB UI in a web browser?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR CommunitiesI have my 963 online, been working great:
https://community.netgear.com/discussions/en-home-orbi-ax/share-your-orbi-350-750-850-or-960-series-system-uptime/2339936/replies/2459332
