muusicman
Aug 26, 2024Aspirant
Possible to get my Orbi RBK 852 to work better without having to factory reset??
I’m having various issues now that I didn’t have when I first purchased my mesh unit. Is it possible to possibly fix the issues without having to factory reset both the RBR and the one RBS I have? I really need to speak with a pro here please. I’ll be forever in your debt if you can get my equipment performing perfectly. I’ve got 1 gigabit fiber from a very small local ISP.
I’ve posted here many times and I’m kinda going crazy! Please help???
"work better" is a bit vague. Hard to offer suggestions without specifics.
Factory Reset is nothing to be afraid of (although most of us think of it as the Last Resort).
- muusicmanAspirantI’d very much rather not do that so I’m glad you said that. Ok so I’ll go issue by issue. I’ll start with one issue and get your take to see what you may have as a fix.
1. My Orbi seems to be going offline multiple times a day. At night too. Not sure how to fix that. My wired devices as well as WiFi devices are seemingly affected.- CrimpOnGuru - Experienced User
What does the Orbi log show at these times?
The Orbi log can be found on the web interface, Advanced Tab, Administration Menu.
It is often a good idea to check with the Internet Service Provider. There was a situation on the forum a couple of weeks ago where the user spend days trying to solve this sort of issue and when the ISP sent a technician out, they found the coaxial cable drop had holes all over it (maybe from squirrels). After the cable was replaced, the problem went away.
If the ISP cable or equipment is causing the issue, messing with the Orbi isn't helpful.
