bobbinman
Jun 22, 2021Aspirant
pre sales advice Orbi RBK 753
Hi I am thinking of upgrading my wifi ro WIFI 6. I was looking at the Orbi RBK753 I live in the UK. My ISP is Plusnet and I am on FTTC connection. My current router/modem/wifi is a Billion BiPAK8800AXL
I was looking at with help getting the Billion put into bridge mode and the connect the Orbi to that. Will this work? I was looking at the 3 pack and the 2 satalites would be connected via ethernet at varoius points arounf my property.
Thanks Chris
For modmes with built in routers...This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite- bobbinmanAspirant
Thanks for the reply, silly question time. Can I just plug in the orbi RBK753 router straight into my socket and configuer it with my isp details? there fore not haveing the oild billion router on the system at all?
Thanks again for your time.
Possible however thats something to ask your ISP about to see what there requirements are. If thats something they support then the RBR should work in it's place. Contact the ISP first and get this information.
