Serge1971
Jul 19, 2024Aspirant
Problem with connecting new satellite RBS850
Hi, today I wanted to add 1 new (extra) satellite (RBS850) to my existing WiFi 6 mesh. It's a simple procedure so I started with the paring via the automised system - add a new satellite. All worked fine, the satellite was recognized and paired... so far so good. Once this was done, I wanted to change the name of the pod so I did. Somehow it lost connection during the change I guess and the original name was left in the base system.... it became impossible to reconnect the new device, I tried everything... removed the new device that wasn't connected anymore via the web interface, even did a full reset and rebuild of my home network... didn't make a change, the 2 older satellites I already had came up in the new config like it was nothing but the new one can't be connected anymore... my tought was that this was due to some hw address that was left in the config but not sure now after a full reset of the base router... any sugestions, ideas or solutions for this??? Would be great, thank you!
Did you update FW on the incoming new RBS to same version of FW thats on the current existing system?
- Serge1971AspirantThank you soo much, that did the trick 🙏
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
