IcedCorn's avatar
Jun 11, 2020
RBK 753 - LED won't go away
Just upgraded to the RBK 753 (AX4200 w2 satellites).
Weird thing though. ...the LED doesn't go away. It's always on. I know many wanted that but I don't. Any thoughts on how to get rid of it (outside of tape)?
  • Has a factory reset and setup from scratch been performed since last update? Something to try on the RBR if you haven't.
    IcedCorn wrote:
    The RBR 750 (Router) has a solid white light on it, . Satellites are fine (no lights).
    Orbi mobile app shows everything as fine, I can use wifi and wired fine.
    Logging into 192.168.1.1 from a web browser is fine, I get the orbi setup page. The LED doesn't change.
    The firmware displayed in the upper right corner of the web browser is:
    V3.2.15.25_1.3.15
  • FURRYe38's avatar
    Which LED is on, the front LED on the RBR or RBS?
    What happens if you log in to the RBRs web page using a PC and web browser?
    What firmware version do you have currently loaded?
    • IcedCorn's avatar
      IcedCorn
      Tutor
      V3.2.15.25_1.3.15
      • Mikey94025's avatar
        Mikey94025
        Hero
        V3.2.15.25_1.3.15
        Strange. Normally the solid white light goes away with a minute after powering up: https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean .  My RBR850 base and RBS850 satellites lights are all off after the system restarts.  I am also running the latest firmware V3.2.15.25_1.3.15.
        What does your Orbi admin website says is the uptime of your system?  http://orbilogin.com/debug.htm shows my System Uptime is 0 days 12:41:17 (I updated my cable modem yesterday and had to restart the Orbi).
