tucsontico's avatar
tucsontico
Virtuoso
Oct 28, 2025
RBK 853 5gHz Wireless Backhaul Issues
About 30 days ago, my otherwise rock-solid Orbi 850 system (RBR + 2 RBS) began to slow way down. After some troubleshooting, I noticed the backhaul was using 2.4 gHz, not the dedicated 5 gHz band and had gone from a daisy-chain config to a star mesh config. The farthest RBS ( about 75 ft from router)  shows "poor" in the connection status. I did a factory reset and a reconfiguration from scratch yesterday via the web GUI (not the iOS app). I'm still getting no signals on the 5gHz backhaul (see attached screenshot). Any ideas?
  • Refurbished RBR850 arrived yesterday. Initialized it and replaced my old RBR with refurb about 1 hour ago. Used backup config file to set up refurb and re-synced sats. After about 10-15 minutes settling time the system came back to daisy-chain topology.  5 gHz backhaul (see screenshot) is working and speeds throughout property are back to historical numbers. (Over 3X faster than when 5 ghz backhaul stopped working).
    Obviously, my original RBR had some sort of tx/rx problem in 5 gHz  band. All is good...for now!
    • FURRYe38's avatar
      Glad you got it working.
      Enjoy.
  • Understand the differences of WiFi 7 vs 6. I do not need WiFi 7, as 95% of my devices are not yet WiFi 7 capable. Was asking about a  RBE773 versus RBK853  coverage/signal strength comparison. (BTW, I have a 1 Gbps down/40 Mbps up connection through Xfinity.)
    • FURRYe38's avatar
      Might try some PowerLine adapters to get the RBS ethernet connected to the RBR.
  • CrimpOn's avatar
    CrimpOn
    "Apples and Oranges"  The 770 and 850 products are entirely different.  WiFi7 with 6GHz (770) vs. WiFi6 with no 6GHz (850)  Different number of antennas, etc.
  • Questions: 1) Does 2.4gHz backhaul prevent daisy-chaining RBSs? 2) Is it possible the v7.2.7.15 firmware is causing this bug? 3) Is the new-ish RBE 773 system measure up to the RBK 853?
  • CrimpOn's avatar
    CrimpOn
    Since you have already done a Factory Reset and have temporarily moved one satellite into the same room as the router, this does not look good.
    It might be time to consider connecting at least one of the satellites with Ethernet cable.  The cable itself is not expensive.  In many houses, the effort to install cable is overwhelming. (why my satellites remain connected using WiFi backhaul.)
    • tucsontico's avatar
      tucsontico
      Virtuoso
      Agreed the effort required to install Cat 6 cable to my RBSs makes it a non-starter.  I've ordered a refurbed RBR from Amazon.com. Will test that and report back.
  • I swapped the locations of my RBSs. Got the same result–no 5 gHz backhaul. After that test, I brought an RBS into the same room as the RBR, placed it about 8 feet away, and powered it up while watching the web "Attached Devices" page. As the RBS finished syncing, it initially showed it was connected to the RBR via 5 gHz with a "Good" backhaul status. Within 60 seconds of noticing that, I watched the "Connection Type" change to 2.4 gHz and it stayed there. Absolutely zero WLAN Backhaul Tx/Rx Pkts listed on the System Statistics page (As per original post screenshot.).
    Starting to think my RBR has lost ability to transmit the backhaul frequency. I used the ancient iOS Airport Utility app to search for signals. It shows the 5gHz backhaul (Ch 157) emanating from each RBS but nothing coming from RBR. Now what?
  • CrimpOn's avatar
    CrimpOn
    As StephenB​ suggested, a screen shot of the satellite portion (top) of the Attached Devices web page would be helpful.
    For example, the Daisy Chain configuration may have been affected by the closer satellite no longer having a 5GHz backhaul connection.
  • FURRYe38's avatar
    Try swapping RBS around with each other.
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
      tucsontico
      Virtuoso
      My house is 3000 sq ft with a 1000 sq ft attached garage/shop (temp controlled). The house has concrete block walls with stucco exterior and 2 x 4 firring with drywall interior (hock and trowel plaster finish). Not feasible to due wired backhaul due to needing multiple holes in concrete block.
      Closest RBS is 35 ft with two interior walls between RBR and RBS1. Second RBS is in the garage about 75 ft from RBR and 40 ft from RBS 1 with two interior walls and 1 exterior wall between the RBSs.
      • FURRYe38's avatar
        This is going to be problematic at best. Concrete and steel will inhibit good wifi signals between the RBR and RBS and thus why the RBS are connecting at 2.4Ghz and not at 5Ghz. 5Ghz can not penetrate well or at all thru concrete.
        Any chance the house and garage are on same power circuit? Something that could work for you to get RBS ethernet connected if you can't get thru the concrete, try some power line adapters.
  • StephenB's avatar
    Are your RBS elements still showing up as synced to the RBR?
    Did you do the factory reset on the RBS also?  Or just the RBR?
      tucsontico
      Virtuoso
      The 2 RBSs show properly synced. I only factory reset the RBR.
