BlackForestGuy's avatar
Feb 02, 2021
RBK353 satellite alternates between solide blue and flashing white
Hi there!
I have just gotten a Orbi RBK353, and got it up an running. The base unit is in my living room, one satellite is on the 1st floor, and one satellite is on the 2nd floor.
Now, the 2nd satellite will always just go from flashing white into solid blue, then start flashing white again, go into blue, and so on.
Anybody has any solution to this?
Thanks!
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    • BlackForestGuy's avatar
      BlackForestGuy
      Hi!
      FW on the NG router is 4.3.4.7_1.9.53 and on the satellite it's 4.3.4.7.
      The modem from my provider (Vodafone) is labelled Arris Touchstone TG3442DE.
      I'd estimate the distance (beeline) between the router and the 1st floor RBS is about 12-15 feet, and the distance between the 1st floor RBS and the 2nd floor RBS is around 15 ft. Of course they're all separated by solid concrete walls.
      Thanks!
