mnichollsuk917's avatar
Aug 12, 2021
RBK752 - Awesome but disconnects on facetime a lot
Hey all
Firstly, i love my RBK752! The router & Satellite have transformed the WIFI in my house but there is one odd issue
My iPhone doesn’t like it, it seems to be ok when my iPhone (11 pro max) is on the main router but when its on the satellite it disconnects, but i never have an issue with the apple TV or the Alexa on the same satellite.
My phone drops out to 4G, then pops back onto WIFI and it just keeps happening
The Netgear page says the backhaul is good, but every now again a blue solid lights appears on the satellite, this maybe happens once every few days for a couple of minutes
Any ideas please? thank you
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try enabling  WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    Armor, Circle, Traffic Meter. Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    • mnichollsuk917's avatar
      mnichollsuk917
      Hey,
      Thank you for the reply.
      My home is 1500 square feet, the satellite is around 30feet away from the router going through 4 plasterboard walls. The link status says "GOOD" but every few days the light on the satellite goes solid blue and i have to reboot to make it turn off
      2.4 is using AUTO
      5 is using 36
      I will now change to 2.4 - 1 and 5- 48 and provide feedback.
      There are lots of other wifi routers in the vicinity
      WMM is already enabled
      I have disabled 20/40Mhz Coexistence
      i can see the CTS threshold but cant seem to amend it?
      when i changed 5ghz to 40 i get a message saying my service rate will drop to 20ghz which corresponds to a 286.6 mbps performance?
      Set Short preamble instead of Long preamble modes -  where is this setting ?
      thanks for your help i appreciate it
        mnichollsuk917
        udpated on above, i have now changed both 5 and 2.4 to short & CTS on both to 2347
