AggedwNG's avatar
AggedwNG
Apprentice
Oct 04, 2022
RBK752 (AX4200 bundle) poor ethernet speeds
Have a 940mbps download speed coming in to an Arris SB8200 modem from the ISP connected via cat6 to an RBK752, with an RBS connected via wireless backhaul. RBK752 internal speed test verifies the 940mbps download speed. However, only 300-400mbps is showing up at a switch (per port) that I have connected to the Lan 2 port on the back of the RBK752. Switch is a TP-Link SG108 dumb 8-port switch (gigabit - 10/100/1000). Have tested wired via Cat6 to the switch with a laptop and desktop both showing only 300-400mbps. Have also connected both (wired) directly to the Lan ports on the RBK752 bypassing the switch and seeing the same speeds (300-400). However, connecting both laptop and desktop directly to the modem and bypassing the Switch and RBK752, yields a 940mbps result on both. Having a hard time understanding why this router cannot seem to output 940mbps on any of the ethernet ports when these are gigabit-capable ports.. I've tried testing numerous Cat6 cables and end result has been the same each time. On the most recent firmware and wouldn't you know my "support contract" has expired, lucky me.. Anyone else running into these issues?
  • plemans's avatar
    What firmware version are you on?
    Are you using any parental controls, traffic monitoring, access control, or qos?
    Try with those disabled.
    Also, how are you testing speeds? (What app or is it the built in speedtest)
    • AggedwNG's avatar
      AggedwNG
      Apprentice
      Hello Plemans. Please see my responses below.
      FW: 4.6.9.11
      No parental controls or QOS, Armor but do have Access Control enabled. I did have a trial version active long ago for both Armor and PC but these have long since expired and deactivated. Tried testing this morning with Access Control turned off on the router, same speed results at the switch and router Lan ports.
      I am testing speed with router's internal speed test and also using speedtest.net on external devices connected via the switch, router Lan ports and modem.
      • plemans's avatar
        I'd try factory resetting the router.
        during the reinstall, tests its speeds without changing any armor/SPC/access control/etc.
