Soloman's avatar
Jun 29, 2022
RBK763S (AX5400). SSID reset required
Ever since purchasing my new RBK 763S, I have had an issue with a requirement to setup a new SSID after my Internet connectivity is dropped, or if we experience a power outage.  If I do not change the SSID many IOT items (including my iPad) struggle to maintain connectivity.  My service provider is Comcast, and my Cable modem is a Netgear CM1100.  There are around 80+ items that are connected via the RBK763S on my home Network so when this does occur, the end effect is that I have to run around a reset the SSID and passwords for all of the IOT items that are on my Network.  It is quite a burden in having to do this for so many of these IOT entities.  Is there a way to get around this?  Any ideas on what could be causing it?
  • Yes. I use 50% on mine. Seems to also help steer devices to RBS as well vs the RBR. Orbi systems are fairly powerful.
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    You don't need to change the SSID or should need a reset.
    80 devices is kinda high...not sure if this will impact or cause what your seeing.
    Can you disable say half of these device and see if this changes the behavior?
    • Soloman's avatar
      Soloman
      Star
      Current Software version is V6.3.1.0_1.1.41.  Separation is ~20 ft to 1 Satellite (also through walls) and ~35 feet to the second Satellite (also through walls).  About half of the devices are wired using Ethernet and Netgear switches.  When fewer items are connected I was still having issues connecting my iPad with the previous SSID, changing my SSID was a solution one of the Netgear Tech support reps suggested after walking through the initial setup with me.
      • FURRYe38's avatar
        Soloman wrote:
        Current Software version is V6.3.1.0_1.1.41.  Separation is ~20 ft to 1 Satellite (also through walls) < this would be WAY TOO close for this one RBS to the RBR.
        and ~35 feet to the second Satellite (also through walls).  About half of the devices are wired using Ethernet and Netgear switches.<What model # are these switches?   When fewer items are connected I was still having issues connecting my iPad with the previous SSID, changing my SSID was a solution one of the Netgear Tech support reps suggested after walking through the initial setup with me.
        What CAT# lan cable are you using?
