thierry38
Jun 05, 2021Star
RBK850 Routeur LAN configuration
Hi
I configured an RBK850 (without satellites for the present time) connected to ans ISP router (network 192.168.1.<x> with HDCP server). So, at the end of installation, my orbi network is 10.0.0.<x>. Wifi and LAN connections are working well and only one PC is connected to ORBI router with an Ethernet cable.
I want to change the ORBI network to 192.168.2.<x>. So, I made the following modification
- IP @ : 192.168.2.2
- Mask : 255.255.255.0
- DHCP from 192.168.2.10 to 192.168.2.254
When I apply the modification, the router is restarted, the LED is white blinking during 1 mn and it restarts again and again. I've to reset it with default settings to stop the restart cycle.
How to do such modification ? (it works perfectly on an old netgear router).
Thanks
Thierry
PS : firmware version : V3.2.18.1
Did you power OFF the ISP router for 30 seconds then back on as well after you applied the change?
Can you bridge the host router by chance? This is a double NAT condtion...
- Yes, I powered off the ISP router and I can access to internet. I just received an answer for neatgear support
It seems the router DOES NOT support to have a 192.168.2.2 IP @. If I choose 192.168.2.1, it seems it’s working well.
I will continue tomorrow (11 PM in France now) And I will give you more information later. I lost several hours with the pb
Thanks- FURRYe38Guru - Experienced User
I now mine works on 192.168.0.1. I've never tried 2.1 though...Hmmm.
Have a good night.
