PedroCavaleiro
Mar 14, 2022Follower
RBK852: WAN Bonding with 4G Modem
I'm planing to buy an Orbi RBK852 Mesh Wifi 6 one of the things that is taking me interest on this specific model is the Mesh and WAN Aggregation So my question before I buy is the following I p...
Morissette238
Mar 16, 2022Aspirant
There are routers from other companies, such as Ubiquiti, which can connect to multiple internet sources and use them both to feed one local network. And, there are LTE modems which can use the LTE connection as a failover in case the primary ISP connection goes down.
@MyBalanceNow wrote:I'm planing to buy an Orbi RBK852 Mesh Wifi 6 one of the things that is taking me interest on this specific model is the Mesh and WAN Aggregation
I plan using this with multiple 4G modems to achive WAN bonding, from the help page I can see that the RBK852 supports this function but the modem must also support Link Aggregation Control Protocol (LACP)
So is it possible to use multiple 4G Modems that have LACP support to use the WAN Aggregation?
If so can somone tell me if the NETGEAR LM1200 has LACP support (I can't find a reference anywhere) and if not some recommendations on brands that manufacture modems with this support
Thank you in advance
- Marnli789Mar 21, 2022Aspirant
Morissette238 wrote:There are routers from other companies, such as Ubiquiti, which can connect to multiple internet sources and use them both to feed one local network. And, there are LTE modems which can use the LTE connection as a failover in case the primary ISP connection goes down.
@ACE Flare Account wrote:I'm planing to buy an Orbi RBK852 Mesh Wifi 6 one of the things that is taking me interest on this specific model is the Mesh and WAN Aggregation
I plan using this with multiple 4G modems to achive WAN bonding, from the help page I can see that the RBK852 supports this function but the modem must also support Link Aggregation Control Protocol (LACP)So is it possible to use multiple 4G Modems that have LACP support to use the WAN Aggregation?
If so can somone tell me if the NETGEAR LM1200 has LACP support (I can't find a reference anywhere) and if not some recommendations on brands that manufacture modems with this supportThank you in advance
You should check this out https://kb.netgear.com/000061324/How-do-I-set-up-WAN-aggregation-on-my-Orbi-WiFi-6-System
