NortieNeil's avatar
NortieNeil
RBK853 AX6000 - Can I use an RBS 50 satellite to extend this network?
Hi folks,
I have a hunch I know the answer, but I'll give it a go.
I already have an RBR50 and two RBS50 satellites which work well, but I've decided to upgrade to the RBK853, which arrives tomorrow.
Can I extend the RBK853's network (albeit with diminished performance) using one of the RBS50s?
I could connect the RBS50 using ethernet if necessary.
I guess I just wondered if the 'new' mesh would accept that earlier model..?
Hope you can help.
Best wishes
NN
  • FURRYe38's avatar
    No at the moment. No idea if or when NG will make prior 50 series compatible wirelessly. You can connect them wired ethernet however.
    • NortieNeil's avatar
      NortieNeil
      Well, that's doable.
      Will it be seen as the same SSID and handover to the other devices in the mesh if connected by ethernet?
