andwheeler's avatar
andwheeler
RBK853 Solid White Light After Power Cut
Firmware Version V3.2.16.22_1.4.9
We had a couple of power cuts last weekend and since then the LED on the modem has stayed on solid white. I have tried power cycling etc. but the light remains on. Everything is working fine but the light remains.  Should I leave it as everything is working ok? Thank you
  • ON the modem? The RBK is a router and satellite system. No modem.
    Did you try powering off both router and ISP modem for 30 seconds then back on with the modem first, then router?
    • andwheeler's avatar
      andwheeler
      Yes, sorry on the router. I have tried switching both ISP ONT & router off for 30secs then switching on the ISP ONT on then router once that booted up and showing green status. White light remains on solid on router. Thank you
      • FURRYe38's avatar
        Guru
        Be sure your using a good quality LAN cable between the ONT and RBR. Cat 6 is recommended.
        You might try a factory reset on the RBR and setup from scratch..
