jmvtev's avatar
jmvtev
RBKE953S FIRMWARE
Does anyone know if there will be an update to the RBRE953S firmware? Seems like it has been forgotten. It is the RBRE950 sold at Costco.
  • Just install the current RBRE960 firmware. It works fine on both the satellites and the main gateway. Attached is my system after I updated.
  • FURRYe38's avatar
    I'll check and see if I can find out anything. I presume at some point there should be since the 950 series is same as 960 series san minor wifi speed differences.
    Are you having any problems with current system on current FW version?
    • jmvtev's avatar
      jmvtev
      Thank you. Just concerned about security and hoping they will add a little more customization to the settings. Like the ability to select other channels than what is available now.
      • FURRYe38's avatar
        You should be ok for now.
        Channel selection won't change from what already offered. Orbi systems only supports certain channels for user selection.
    • jmvtev's avatar
      jmvtev
      Thank you Apanola. I'll give it a shot. How long have you had it on that firmware? Any issues?
