madger's avatar
madger
Tutor
Nov 26, 2022
RBKE963 limited wifi channels
First off is there a way to separate the 2.4 and 5 ghz?
i am able to separate the 6ghz.
also the 5ghz channels are limited to 36 through 48, which are very congested in my area, does orbi have access to the higher 5ghz channels?
  • CrimpOn's avatar
    CrimpOn
    If by "separate the 2.4G and 5G" you mean assign different WiFi SSIDs to them, then no.  Orbi routers do not support this.
    There are only two 80MHz wide groups of 5G channels available in North America, 36-48 and 149-161.  Orbis use the lower frequency for user facing channels and the upper group for the connection between router and satellites ("backhaul").
    https://en.wikipedia.org/wiki/List_of_WLAN_channels
    And, yes. that group of channels is extremely congested.
    As a point of interest, selecting a specific 5G channel means that the Management Frames used by the router will be on that single 20MHz wide channel.  The router still uses channels 36-48 if they are open in order to maximize transmission speed.
      • FURRYe38's avatar
        If you have a area thats is congested with nieghboring wifi, try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
