fdelmo10
May 07, 2025Tutor
rbr 750 firm V7.2.7.15_5.1.16
MY wifi is not strong on firesticks and phone. on my wired pc is getting 325 plus reading. I have Enable AX - This WiFi mode will enable AX features ,What other setting should I try . My wifi is reading 20-35 vs the 325 wired
Are those speeds?
What brand and model phone do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Do you have any RBS deployed as well or is this just the RBR only?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageTry disabling the following and see:
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
- fdelmo10Tutor
The speed is 594.92 mbps on my pc thru the router app My phone is a galaxy 22 speed 52.85 mbps I have 3 additional satellites in my house 4200 sq feet. I have a spectrum modem DOCSIS 3.1 Modem. My wifi channels 7 and 48 I have 33 devices connected 12 at 2.4g, 17 at 5g , 4 are wired
Can you try setting channel 11 and 48 on the RBR.
Then turn OFF two RBS for now leaving the RBR and just 1 RBS deployed. Later lets turn on a 2nd RBS after checking this.
Be sure that your disabling then re-enabled WiFi on wireless speed testing devices when you are near the RBR to ensure they are connecting at the RBR and not a remote RBS. Be around 6-10feet away from the RBR.
- fdelmo10Tutor
All done the devices reconnected to the rbr750 Speed was 82 for the phone 18 for the firestick the wired pc speed 573
- fdelmo10Tutor
No we have not ever done that as far as I know
